65 Valiant door handles
737jetdr
Martinsville, In.
Can anyone tell me if the front outside door handles are the same as the back outside door handles on the 4 door? Car is not here and I can't seem to locate my door handles at the moment. Thanks.
The "outside" part of the handles are exactly the same. The linkage points on the inside of the rear handles are different to hook up to the linkage rods inside the rear doors.
I just located mine and I see what you mean. So in theory, I could order 4 front handles and swap the linkage out to work on the rear doors? I haven't seen any rear door handles for sale.
You are correct!
No door handles specifically for the rear doors are being offered, and you can swap out the linkages to get them to work for the rear.
