650 dp Carb Big enough?? Opinions Please
1972orangebeast
Newark, Ohio
I have a 69 340, .030 over, 10 to 1 comp, stock x heads, running elderbrock rpm air gap and cam is going to be a Comp nostalgia plus 20-674-4 ADV. DURATION 292/299 VALVE LIFT .508/.508. My question is i have a holley 650 DP is that enough for my car? Or should i go 750? Just Rejet to bigger jets?
-72 dart 4spd 323 surgrip
-Not drag racing just a street car, if anything might autocross or something
Shesaid has told me to go bigger but looking for some other .02 cents :D
Your 340 is close to mine, Isky 505 cam, stock 340 heads with a little work, 2.02/1.60, I also have a 4-speed, 4.10 gears. I have a M1 intake with a 1" Super Sucker carb spacer, I run a 650 DP and it works great! I have messed with the jets a little from time to time, I run it on the street and it does see track duty, works nice when driven hard :D I have always wanted to try a bigger carb but I don't think I need to.
