[SOLD] 650 Holley spreadbore
gliderider06
Delaware
Almost new, holley 650 spreadbore carb. List 7002-1. Used a short time and pulled off. You may need to pull the bowls off and check if any gas dried and left a residue behind, but should be good. Close to $700.00 new.
Asking 175.00 plus the ride.
what is the measurement of area where air cleaner sits on top under the butterfly plates
It takes a standard 4bbl aircleaner, 5-1/8" . I use a factory aircleaner on mine.
