[FOR SALE] 66/67 A and B body Bucket seat frames and slides ---MOTIVATED---
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
---NEW LOWER PRICE, OBO---
I'M VERY MOTIVATED!!!
66 A body (also interchanges with 66 & 67 A & B body)
The seat base is the same part number 66 & 67 A Body, and 67 B Body (may also be the same for 66 B Body)
The backs interchange 66 & 67 A Body, and 67 B Body (may also be the same for 66 B Body) but they do not have the provisions for a head rest that a true 67 has.
All parts have been primed after professionally media blasted / chemically rust removed. They come from a wrecking yard here on the front range of northern Colorado 80526. It is now completely crushed out and bare dirt. :(
Seat base #1 and #2 have some rust along the rear edge.
#1 is the most extensive and the backs of the springs are rusted as well
#2 has some rust on the rear frame but the springs look good with the slightest amount of pitting.
The rest are in excellent shape.
#1 seat base (this is the worst of the lot)
$25.00 plus shipping
#2 seat base (this is the 2nd worst of the lot)
$35.00 plus shipping
#3 seat base
$40.00.00 plus shipping
I might have forgotten to say.... IM MOTIVATED!
More
I AM VERY MOTIVATED.....
All are in excellent condition
#7 seat back
#9 seat back
$40.00 plus shipping
DID I MENTION I'M MOTIVATED!
More
Slides are 66 specific and only the upper 1/2.
Each set, #12, #13 is a left and right for one seat
(No way I was going to stick my hand in under a car on blocks for 50 years :eek: )
All slides were hot tanked then media blasted and primed.
There is no grease on the bearings to not contaminate the paintable surfaces.
All levers mode freely and the slides open and close as they should. The slides are stiff with no lube but once painted and lubed will slide as expected.
All are in great shape with only the minimalist amount of pitting on #12 & #13 along the bottom most edge
During the cleaning process one large ball-bearing fell out and was lost, I bought Stainless Steel replacements and replaced it (I don't know which slide it was but once the bolts and nuts are attached to the seat base the ball can no longer come out)
#12 (passenger)
$20.00 plus shipping
#13 (passenger)
BTW... DID I SAY I WAS MOTIVATED
