[SOLD] 66/67 A and B body Bucket seat frames and slides
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
---NEW LOWER PRICE, OBO---
I'M MOTIVATED!!!
66 A body (also interchanges with 67 A & B body)
The seat base is the same part number 66 + 67
The backs interchange but do not have the provisions for a head rest that a true 67 has.
All parts have been primed after professionally media blasted / chemically rust removed. They come from a wrecking yard here on the front range of northern Colorado 80526. It is now completely crushed out and bare dirt. :(
Seat base #1 and #2 have some rust along the rear edge.
#1 is the most extensive and the backs of the springs are rusted as well
#2 has some rust on the rear frame but the springs look good with the slightest amount of pitting.
The rest are in excellent shape.
#1 seat base (this is the worst of the lot)
$25.00 plus shipping
#2 seat base (this is the 2nd worst of the lot)
$35.00 plus shipping
#3 seat base
$40.00.00 plus shipping
#4 seat base
---SOLD---
#5 seat base
---SOLD---
More
All are in excellent condition
#6 seat back
---SOLD---
#7 seat back
#8 seat back
---SOLD---
#9 seat back
$40.00 plus shipping
More
Slides are 66 specific and only the upper 1/2.
Each set, #10, #11, #12, #13 is a left and right for one seat
(No way I was going to stick my hand in under a car on blocks for 50 years :eek: )
I have 3 of the same side and 1 of the opposite side. #10 & #11 would make a set.
#12 & #13 are the same as #11
All slides were hot tanked then media blasted and primed.
There is no grease on the bearings to not contaminate the parable surfaces.
All levers mode freely and the slides open and close as they should. The slides are very stiff with no lube but once painted and lubed will slide as expected.
All are in great shape with only the minimalist amount of pitting on #12 & #13 along the bottom most edge
During the cleaning process one large ball-bearing fell out and was lost, I bought Stainless Steel replacements and replaced it ( I don't know which slide it was but once the bolts and nuts are attached to the seat base the ball can no longer come out)
#10 (drivers)
---SOLD---
$20.00 plus shipping
#11 (passenger)
---SOLD---
#12 (passenger)
#13 (passenger)
If someone can identify left from right for me I'll update the listing.
The way you have them bundled, it looks to be the other way around.....3 driver and one passenger.
Mine are still installed on the seat with the side panels, so, not all that easy to see details.
