j par
Well-hung Member
I get both are 48 years old, but is this a common problem?
I have two 273's also. One is a Commando and right now I am working on removing the intermediate shaft so I can have my wife spin up the oil pump while I look for the leak. It seems like it could be the rear main seal. Once I get this blasted intermediate shaft out I'll find out for sure! My other one does not leak, but the steering box leaks a little. Leaks and rattles bug the crap out of me. The only rattle on my Commando is the floor console rattling when I fire it up with the gear reduction starter!!!
Good luck finding your leaks...I'm hoping the trick of spinning up oil pressure without the motor running will help me find my leak. To do it, you need an oil priming tool (I bought one from summit for $9.00). Pull the distributor and the intermediate shaft, then the primer tool goes onto a drill and fits down into the oil pump. I hear you get oil pressure up to 40 or more pounds so that should help you find out where its leaking.
If you would've bought them new, they wouldn't have leaked then.....
If I was 48 years old I would leak too........:glasses7:
