66 dart offset master cylinder push rod to brake pedal?
If it's like 67-up you just move the rod to the other side of the pedal. You have to use an adjustable length push rod to make up the difference in the adapter thickness.
Mancini Racing sells what you need.
Yes just move the push rod to the other side of the brake pedal and cut the push rod in half add a spacer that is the thickness of the spacer you use and I used a piece of DOM tubing as a sleeve over the ends of the push rod and the spacer and welded it together. You will never have to worry about the rod breaking if you have to panic stop. Good Luck
