[FOR SALE] *** 67 383 engine***
4fortyDemon
St George, Utah
Just bought this a few months ago for a 67 Valiant project that I planned on putting together. Well, life changes.
This is what I know about it and what I've seen since acquiring it.
It's a 67 engine (supposedly from a Fury) its 30 over and #3 cylinder has a sleeve. Its clean inside . The top of the pistons were cleaned off. That's as far as I know about it. The heads are 915's and the one cylinder is missing valve springs, keepers and retainers. One valve I think is bent because it doesn't come out.
Has no intake it HAS exhaust manifolds. No distributor, no mounts, IT HAS A water pump
It does have a nice 187 oil pan for a body swap.
My plans were to disassemble, hone, rebearing , rering and gasket it. And obviously go through the heads. Replace the cam and lifters, timing chain/gears, and go.
$400.00 also have a bigblock 727 for sale too as a good core $175.00
Located in Douglassville Pennsylvania
Local pickup only. Can deliver to Carlisle if paid for first
I found a points distributor and a cast iron 4bbl intake that goes with it.
