[WANTED] 67 383 Unsilenced Air Cleaner Base
CL3406
BC
Hello, the previous owner of my 67 Barracuda lost the air cleaner base of all things. It is for an AFB carb so center hole is 4.5 inches & outside diameter is 13 inches. Hopefully someone has one in their stash. I have attached a picture, off of this site, showing a top & base for reference. I only need the base.
Thank you.
Thanks for the info. I will keep trying for the original for a bit. Isn't that Mr gasket adapter too small at 4 7/32? AFB's are right around 4.5". Unless you have tried this set up with the original top and saw that it works?? Thanks.
Maybe I linked to the wrong adapter, I know I used one on an early AFB years back (smaller than 5 1/8)- I thought that was the one. There are others. Just thought it would be something to get you on the road while you look for an original base which, like I said, are far and few between.
4 7/32 ID is the right size for early AFB's. I might have an original base, will check tomorrow. Or you can find a standard base and cut the outer diameter to the filter pad. That 4 7/32 ID is used on most AFB's up to 1967 and larger 2 barrel carbs on big blocks.
This is what I could find. It is a cut down original.
I also have this one, you could cut down to be very close to original.
