[WANTED] 67 68 69 70 Factory Front 10 inch drum with left hand studs
davescuda
Cheshire, CT
Must be in real nice shape or NOS
If you have the right also I will take both
Thanks
I have both left & right sides & I think they are originals. I will check for size & condition. I'll let you know by Tuesday night. Just need the drums right? I do have the whole assemblies including the spindles too if needed. They are from a 69 Dart GTS.
I have the right side nos
PM sent
thanks
I took what I have apart & they measure 10", but someone replaced the studs a one time because they are RH threads & drum from left side is kind of messed up. The one on the right side looks much better but again it has the RH threads as it should. You could install LH treaded studs on that drum if you want. These are the pics. You can decide what you want to do.
Thanks But I need it with left hand studs.
I have the complete stock front end out of a 68 form S fastback , can check the drum for left handed threads , if u still need them .------bob
The drum and the stud threads have to be in good shape.
Thanks for looking
