[WANTED] 67,68,69 cuda 4" bolt spread front drum brake hubs
jimharvard
JimHarvard
Pittsburgh, Pennsylvania
i need one or two front brake drum wheel hubs with 4" bolt circle for a 68 formula s cuda with 10" front drum brakes. i think 67 and 69 drum brake hubs are the same. lug studs should be 7/16" by 20 R threads. willing to pay a lot for these parts. jimharvard here at FABO.
Those 10" interchange all the way through 1972 and back to at least 1965. From the factory only the right side is right hand threads.
oklacarcollector...
thanks for the information. i don't want to go back to left hand threads. my original 68 cuda (back in 1969) was left on the left and right on the right and gas station guys were constantly twisting the lugs off. i have cragars on my current car with 4" bolt circle front/back. one of the studs is lose on the front hub and the cast hub won't hold a weld. i want to replace the hub with one with tight lug bolts. the lugs need to be 7/16" by 20R threads 1 3/4" long to fit the cragars. if you have these hubs or know of where i can get them please let me know.
thanks for your response.
jim coster, pittsburgh, pa
kbsouers
hi.. would love to buy your old hubs. please quote me a price with shipping to 1108 peachtree road, carnegie, pa 15106
jim coster
Jim I need to send a few pics first. I would like to sell both assemblies. I had craigers on these once. the lugs acted like sleaves in side the lug holes helping lug nuts re ach the short studs. I cant remember if I converted the left hand hub to right hand threads or not .
I will take pics tomorrow
I believe I have one right hand hub with the original studs. If the above poster doesn't have a pair let me know and I'll check the condition of mine.
Dallas
I have a pair of SB pattern stock hubs with RH 7/16 thread studs and would sell one or both but all stock SB factory lug studs are only 15/16 in used length and would have to have been replaced if they are longer than that.
oklacarcollector...
These are left and right thread. feel free to buy from any one who has closer to what you need. If you wanted to pick these up ill give you both assemblies for $40. just as you see them in pics.:coffee2:
