[WANTED] 67-69 barracuda notchback trunk drip rail and quarter section
moparmat2000
Grand Tetons
67-69 barracuda notchback drivers side and passenger side complete side trunk drip rails, and section of the top of the quarter panels. Need pieces that are not bubbled to **** with rust since that is what i am dealing with now. I need them cut past the front and rear seams as shown in pic.
Thanks
Matt
I am replacing the dutchman, and rear valance. These pieces are fried though. LH may be repairable, RH is shot as you can see from pic. I will have to do a little metal work in corners of rear window. For some reason i cant post pix but LH quarter on top is rough. Car was minitubbed with alum tubs and pop rivets. The roof supports that tie into outer wheel houses were cut off at the bottom. I am going to unfuck the back end of this car. Will either fab new roof support lower pieces or try to find some i can graft in from a coupe when i put wheel houses and quarters on it. Not sure what all you have.
LMK
Thanks
Matt
I got to really picking away and looking at my flanges and the drip rails on both sides this afternoon. They are both fine. A little scaley but solid, and will easily clean up with a sandblaster. Its the quarter panel thats the problem where its stamped to curve inward, and where it overhangs the rail on the RH side. I have a master plan for this. I may have to fab up out of sheet stock a replacement piece, and install it in place of the damaged quarter section. I do aviation metal fab so this shouldent be too hard to do. Just have to think up a plan of attack. Sure wish AMD made coupe full quarters instead of having to hang goodmark half skins on it.
