[SOLD] 67-76 4 Speed Swap Kit Northern California
FourSpeedDemon
Nor Cal
Just about everything you will need to swap a 4 speed into your 67-76 A body. A mix of new, NOS and good used parts.
1967 A833 4 Speed Transmission
68-72 Aluminum Small Block Bellhousing
New Bellhousing bolts
NOS Bellhousing starter and clutch shield
NOS Mopar Shift Fork and Pivot
Original used shift fork boot
Bellhousing and frame brackets
Z bar modified for Dougs/TTI headers
Z bar hardware
New clutch kit
New throw out bearing
Clutch pedal rod used
New Pedal Rod firewall boot
New AMD 4 speed tunnel hump
4 speed pedals from 70 Duster
Hurst Competition Plus Shifter
Shifter Adapter
Shifter rods with swivels and tabs
Located in Woodland CA 95695 no shipping $2200
