gregpurcell
Greg Purcell
This is a good used power steering column coupler for a mid 60's early 70's A B or E body car with power steering. It includes the "guts" that go inside, a used rubber seal which may or may not have any life left in it, the outer seal retaining clip and the roll pin that holds it in place.
It has been wire wheeled and is ready to go!
This is one of the parts that you will need to swap from manual steering to power. Remember that the manual steering shaft will have to be shortened and that the geared hole on the coupler is larger on a manual steering box than on a power box.
Located in Savannah, GA I'd like to get $35 and I'll cover the shipping.
Thanks for looking!
Thanks for looking!
