72 340 DUSTER
i have for sale a A/C heater box out of a 74 duster. this heater box is in immaculate shape and comes with absolutley everything. it comes with the blower motor, heater/ A/C controls w/ cables, under dash A/C vents, and 2 differnt heater/A/C control bezzels, one restored just needs wood grain over lay. this is one of the most complete kits i have seen in a while in this nice of shape, it is everything you need to convert your non A/C car to A/C as far as interior wise. if you are restoring a non a/c car and plan to convert it you will run into 2 problems. one being that the hole in the firewall is substantially bigger and odd on all a/c cars, this is due to the different blower motor size that the a/c uses. your other problem will also be on the firewall, this one is less of an issue but is that the heater core lines will be located in one single oblong hole in place of the non a/c style that has two seperate holes. to commendere this issue i will cut these peices out of an old firewall i have laying around to you have a templete to fab up your new a/c firewall. this kit comes with all of the nessesary hardware to make the switch. i am asking $200 for the entire kit and will give you the firewallpeices for free if you need them, please send me a pm w an email adress so i can send pics to you for they are too large to put on FABO, thanks
