67 Barracuda back window
wlecat
Ewing, NJ
My back window is gone. Are the back windows they sell Just the part between the zipper and bottom that includes the window section?
Or do they attach somewhere else? Is it hard for a non professional to do?
Will I need special tools or take part of the top off? Which mfr. fits the best for a very reasonable price? A plastic window is fine.
LOL...yeah, that's why I posted it in the convertible forum. Like the Lincoln quote.
If you can peel the top itself off far enough to install a new glass without destroying the top itself... No special tools required except a stapler and the short staples.
Upholstery shops will tell you the same, "failed glass equals new top with glass".
This chapped the buns of very many Lebarron owners in early to mid 90s.
Of course they do, they make more $ that way.
The more work you do on your car yourself, the better you know when someone is trying to rip you off. The problem of doing the work yourself is usually tools and facility.
The back curtain can be purchased separately from the top and should be able to install it yourself
Remove your boot well and you will see how it is held in
