Started working on repairing sloppy door hinges on my 67 Fastback. I purchased pin/bushing kit for the uppers and what I thought were going to be new OEM hinges for the lowers (Figured new lowers would be best option long term). When I got the lowers I opened the boxes and both hinges had bushings in them (Rebuilt?). Cost me $176.00 for the pair. Bushing kit would have been $10.00!
Anyway, with the old hinge on the door I marked the current location on the door and car mating surfaces. The door was originally sagging about 1/4 inch low and gap at latch was about 1/4 inch as well.
I removed old lower hinge and installed the (new) hinge. Problem is the new hinge will not slide to the rear far enough to line up with my marks on the body where the original hinge was located, so I now have about 3/8-7/16 inch gap back at the latch. Looks really bad.
This is my first door hinge installation so I may have missed something? Anyone have any thoughts/ideas as how to proceed? Thought about just buying the $10.00 kit and rebuilding existing lowers since the door wasn't off by that much with a worn out hinge?
Does anyone know of a video showing steps on installing hinges on one of these 67-69 A-bodies and door re-alignment?
Thanks to all
Thanks to all
