Just a heads up. If one of the hubs you're getting has LH studs, and you plan on replacing them with RH studs, be sure to read the Threads on this before you remove the old ones. It can definitely be done, you just have to do it correctly. I (and others) have learned the hard way. Since the drums are separate from the hubs, this may not be an issue.
