DonnieLawson
68 Barracuda
I have 2 fenders, Right and left for a 67 Barracuda. Holes can easily be cut for marker lights for 68 or 69 .
The fenders are as straight as any I have seen, drivers fender has no rust or rust repairs. Perfect sheetmetal
Passenger fender has a very small spot at the very bottom of fender in front of the tire, its shown in these pictures. You cant see it unless your laying under the car, easy fix.... Also has a previous rust pinhole repair show in pics, its lower rear of fender by the brace. Cant tell its repaired unless you have the fender off.
These came off a race car, the headlight buckets are cut off , and most of the top metal where they bolt to the inner fenderwell.
They are perfect for a race car , and a person could use old headlight buckets to use these on a street car again.Good Metal fenders are almost impossible to find as I have found out.
I'm asking $450 or best offer for these , prefer local pickup. May deliver to a local show. will not separate
Fiberglass fenders start around $350 each and these fit and look like OEM should.
Located in Middletown Ohio, Between Cincinnati and Dayton
Thanks for looking....
Donnie
Donnie
