67 Barracuda front grill problems
yes I rebuilt mine.I thought it was a piece of garbage but it looks like new now. first grind all the rivets and dismantle the grill removeing the steel brackets that the studs were in (i sand blasted the steel parts)nock out the old studs. Then get machine screws with counter sunk bevel heads and tack weld them in the old holes with a mig or tig welder. By the way that silver frosted paint color is argent. Then rivet it back to geather and you will be a happy man. good luck
