yarcraft91
My '67 Barracuda has the rallye dash and it needs work. Recently, both the temperature gauge and speedometer quit. Temp gauge reads about 1/3 scale when ignition off or cold engine, slightly lower when the engine is warmed up, does not respond when the sensor wire is shorted to ground, voltage limiter appears to be working. Speedo head seized and snapped the end off the speedometer cable. It looks like I might need to pull the dash instrument panel and all the stuff that goes with it and get these gauges repaired. If I do that, I'll have all the gauges rebuilt.
The last time this dash was pulled was 1974 and I remember the Plymouth dealership mechanic griped that he spent the whole day doing the job. So, how bad is this job and is there a high risk of screwing up something that makes it worse (like breaking electrical connectors)? My alternative is to leave the dash well-enough alone, mount an aftermarket temp gauge and use a Garmin GPS for speedo/odo. Right now, I have a dependable driver where everything works but those gauges- I'd hate to screw that up.
