67 barracuda trunk drip rails
65gt360dart
Member
Hi all. I've recently purchased a 67 barracuda project. The body is in pretty good shape except the rear window down to the trunk drip rails. Does anyone make a replacement or does anyone have these for sale
Common problem. I am repairing the damage on my 67. My sons 69 I bought the back end of a cut up 69 coupe from california and harvested the decent rust free steel out of it to replace my rotted trunk rails. Nobody makes it repop. Either steelbn patch repair it, fab replacement pieces , or find a rust free cadaver to cut out what you need to splice in.
If the donor *** end i bought didnt pop up, i would have had to fabricate this stuff up out of sheet steel.
I have found that the E body piece works for the top corners. You have to cut off the lower part where it turns, but the top works. Obviously the only for one layer. There is like 3 pieces that come together there.
I have found that the E body piece works for the top corners. You have to cut off the lower part where it turns, but the top works. Obviously the only for one layer. There is like 3 pieces that come together there. View attachment 1715640201
If you're looking for used ones you will need to start a wanted thread in the "Mopar For Sale Ads" forums.
