67 barracuda Trunk Trim clips?
MrBelvedere2
Sacramento, CA
My question is regarding the rear trim on my 1967 barracuda. I was able to find some used trim for the trunk lid. the previous owner filled in the holes when he painted the car. The trim I go does not have any mounting clips or studs on it, and I'm not sure what clips or studs to use? the middle trunk piece has studs but no nuts. So where can you get the rear clips for the trim? how do you attach them to the trim?
the upper and lower trim uses regular T bolts. They side in through a notch in one end of the trim.. The T bolts on the very ends need to be short so they dont dig into the body.
