67 Barracuda - Work in Progrress
MechEngr
Member
Palm Coast, FL
I been working on this 67 Barracuda for about the past year and a half with the mechanical portion of the build finally completed.
360 Magnum (.030 over to 365 CID)
Comp Cams: Duration 265/273, Lift.506/.506
Kieth Black Pistons (KB107.030, 10.5:1 CR)
PIE Heads (Stage 1 Ported)
Edelbrock Air Gap (Port Matched)
Mopar Perf. Timing Chain and Gear Set
Holly Sniper Hyperspark Distributor
Holly Sniper EFI and 340 lpm Fuel Pump
FlowCooler water pump
Kevco oil pan
TTI Shorty Headers
46RH Transmission
8 3/4 differential with 3.23 gears (shortened 2")
Borgeson PS
4 wheel power disc brakes
I still have a lot of work left to do. There are a lot of mysterious rattles and electric bugs to fix and the body work could use lots of help.
Takiing it a dollar at a time.
The underneath of the car required substantial repairs. One side of the rear frame structure was destroyed by rust. The front and back mounting plates for the springs were rusted out. The crossmember for the torsion bars and transmission was cracked/split beyond repair. One small section of the drivers side floor was rusted out. All were replaced and welded in with new metal. The 46RH transmission didn't required modifications to the tunnel and was one of the easier pieces to install.
