[Found!] 67 dart dash frame
Your in-box is full. I have one from a 74 A body & close to you in Pa.
It looks like 67-69 darts had the ignition on the dash but 70 and up has them on the column. I am not sure if there are any other differences but I need a dash that fits the 67 stock instrument cluster/ gauges and has the ignition on the dash. Thanks
Yes you need a 67-69 Dart frame. All others are different.
67 68 and 69 are all different
67 has a round knob radio and no holes drilled for a Vin tag.
68 has a bunch of holes drilled for the lower pads, and holes for dash vin.
69 has Vin holes and a thumb wheel radio, making it completely different.
Yes extra holes can be welded...but the metal is thin, easily warped, and would require more work.
67 is a one year only due to the radio opening.
Very good
