smitty040
I've been trying to tackle a horn issue and need some direction. So far I've established that the horns and relay both work.
I have removed the steering wheel and took steel wool to the copper ring and spring wheel under the steering wheel before putting the wheel back on.
I've disconnected the horn switch and took a lead directly from the negitive side of the battery and touched the black wire that connects to the switch and the horn sounds.
I can not make the horn sound by simply touching the steering wheel retaining nut/shaft with the black wire.
I took a jump wire and created a ground wire from the column cover bolt to stud as shown in the service manual and still nothing.
Took an alligator clip wire from the bottom of the dash and touched the black horn wire and the horn sounds. Makes me assume the dash is grounded.
I'm pretty much at a loss of where to go from here. Any help would be great!
Thanks!
Thanks!
