I used a kit that was 2 part epoxy called PC-7. That stuff was tuff to say the least. I found that you really needed to work it to rough shape before it really hardend up fully. I used an air grinder and dremmel at first. Once I worked with it a bit I found it easier to rough in with graters and files before full set then used progressive grades of emery cloth to get right. At least 40 hours of work to final paint and clear coat. You have to really want it!!!
