'67 Valiant 2 door sedan - Rear glass gasket cross section or source of replacement
Garry in AZ
Building a 9 second Valiant
Mesa, AZ
Howdy folks, I'm looking for a rear window gasket for my '67 Valiant 2 door sedan. The rear glass is not the same as a Dart, or a hardtop model. I've tried all the usual suspects, Auto City, Just Mopar, Laytons, etc.. no luck. If I could come up with a dimensioned cross section, I might be able to find something that would work at Steele... Anyone have any insight on the best way to proceed?
The image below was snipped from the shop manual, but I'm not sure it's for the Valiant. And, there are no dimensions.
If your back glass gasket takes the lock strips like most all of the other '67 models, it's probably a unique gasket for that year. The '68 Valiant uses the same glass, so, that gasket may be an option too if you get the stainless trim and clips to go with it. Both '67 and '68 Valiants have the same back glass. There were no hardtops those years....only 2dr and 4dr sedans.
