cgray521
So when I bought the Valiant, the seller included manual-disc spindles, calipers, and rotors. (their origin unknown). So far I have swithed to 72 Demon upper control arms with large ball joint, cleaned and painted (inspected) the rest. The parts I've been buying are from a 74 Swinger w/v8, and they all appear to be a good fit so far. But now the caliper is in front and the brake line wont reach (which one to buy?), and I have no idea what master cylinder to buy. (I will be using a Ford 8.8 drum brake rearend and adjustable proportioning valve.) Also what is the torque spec on attaching the upper control arm (a-arm) to the frame?
