What do I need to change 67 Valiant stock front drums to disc brakes??? New spindles???? New ball joints???? New upper and lower control arms??? Thanks Steve
Upper control arms,spindles, rotors, calipers from a 73-76 A-body Disc brake car. Or if you want to stick with the small bolt pattern wheels, 5 on 4". You will need the Kelsey Hayes set up from a 66-72 A-body with disc brakes.
Wilwood has set up for 9" or 10" drum spindles plus you can go 4" or 4 1/2" bolt pattern. Will run you about $700, another option for you to think about.
