[WANTED] 67 valiant signet dash frame
beepin72
shiloh,il
Rating - 0%
0   0   0
looking for a dash frame and heater/radio bezel, glove box bezel for a 67 valiant signet, also an edelbrock ld4b aluminum intake for a 273 thanks
I have a valiant plain dash,you will have to drill the holes for the trim. There are a bunch of those trim plates on feebay.
I have the plain 67 dash, I drilled the holes and have the trim. I don't have the nuts that hold the trim on, thought if I could find the whole dash complete,
I think they are the same ones that hold the console plates to the console housing. They are stamped tin washers and 1/4 wrench.
I will check into that, I had some tin washers, all were to big thanks
I took this dash bezel off yesterday. they are actually 3/8" hex speed nuts. beeper i sent you a pm saying i would send you the six speed nutz I removed (seventh was missing) for no charge. If you wanted the bezel - $12 shipped USPS with the six speed nuts. Bezel is cut for an aftermarket cassette deck, and one stud on back is broken off - hence the missing seventh speed nut.
