68 Barracuda 340
johnnycuda
JohnnyCuda's 68
Hey Guys a Few questions:
I just picked up that 68 340 Barracuda.
5th digit is “P” So its a 340 car correct?
Vin# matches the Engine & 4 spd trans.
It says Formula S on the fender.
But no 150 speedo & No tach.
trim tag is there but from BH23 car.
So no F7 to go by on Tag
Just wondering can you get a p code 340 non formula s car? or are all p code cars formula S?
Either way i am fine with it.
Was maybe going to find a Roller to put drive train in, if body resto is too much for me.
It has an 8-3/4 3:55 sure grip
I’m assuming the cluster was changed? Or has anyone seen one without tach and 150 speedo?
Just tring to figure out what exactly I have here. Also rad is off by one.
If I’m reading it right 2988027 is for a 273 automatic
298026 is for a 4 spd car see pic of rad list.
Thx in advance johnny
If it appears the rear seat is OE, get it out carefully & look for the broadcast sheet, could be under it or on floor partially under carpet.....most times it's between bottom cushion & spring wires.
Also pretty confident that all 1968 340 & 383 models were Formula S, unlike 1969. Tach or Vacuum gauge were optional on the package, and I have seen a couple of originals with 120mph speedos.
