68 barracuda fastback
crycho
Klienberg, Ontario
Driver side rear side glass does not roll up properly. Always moves up to the inside of the car so much so that it hits the interior upper trim. I have adjusted the bottom guide in ward as much as it can go. I have no idea why it moves to the inside so much. Anythoughts?
Top and bottom of the channel is adjustable. Also check the condition of the roller assemblies.
The frame under the glass is cast aluminum, so is unlikely a problem. However there are three roller assemblies that can be problematic. I think there are two small bolts that hold the glass to the aluminum frame, check those also.
