rednesss
You know that plastic piece that goes under the hood inserts that disintegrates as soon as you remove the hood inserts??? I don't suppose that there are replacements available??? Or does somebody have a recommendation on how to replace it with a substitute material??? I guess it's just there to prevent the hood inserts from vibrating through the paint and into the metal and then rusting???? Any suggestions would be appreciated. Thanks.
