Moparparts
FOR SALE: 68 Barracuda or Cuda passenger's side original steel front fender. There are no rust holes on the dog leg or top mounting edge. The only small rust holes there are is at the back of the headlight cup mounting opening, a few small holes there. All the valance mounting hole threads are OK with no broken studs. It does have some small dents on the front area, but has not been collision damaged or previously puttied/repaired any where else that I can see. There are 2 small cracks on the lower valance mounting edge and a small one at the bottom front edge of the wheel opening. It had surface rusting on the inside with light pitting that had been hand cleaned and spray primered. The antenna hole has an extra slot on the edge but an original bezel was tried on and does fit and cover correctly. A very hard to find passenger's side original fender with no rot through on the outside or fender mounting edge. $350 plus shipping. Prefer local pick up in Pa 17086, but can be shipped.
