[WANTED] 68 Cuda Lower Vent Window Chrome
ermarccio
Dracut Massachusetts
Rating - 0%
0   0   0
I need both the right and left side vent window chrome peices. Just the lower peice with a pivot stud as well as the window latch. The fewer pits, the better. I believe these are the same for several year Darts. I can attach a picture later if it helps.
Thank you!
Eric
Eric they might interchange with other yrs. but there's little differences with the window latch design. If you don't care if their year correct you can use anything but if you want the latches to look the same get them from the same year and model car.
