68 dart fender interchange
cjfivered
New Member
looking for left side fender 68 dart. do other years fit like from 67-70,71?dont mind filling or drilling holes for marker lights email to cjfivered@aol.com thanks
I was told 67,68,69 fenders are the same, except for the marker lights. I'm not sure about 70 and up though.
69s aren't the same.
The headlight area where the bezal sits is deeper, so the screws won't even come close to lining up.
'70-72 won't work for the reason that they have the removeable fender cap.
I know that the '73-'76 Dart fenders will fit and retain the headlight bezals, if you use the '68 plastic bezal screw inserts and the marker light hole s easy enough to fill and relocate.
I do have a '68 driver's fender here that needs a minor patch at the lower edge and the bracing is not rusty.
A simple patch would fix it.
Mark.
