Hello
We picked up a used never been painted 6 -pak hood like new condition but someone had previously drilled hood for pins. Why they drilled hood I’m not sure as where you attach the hinges still had a rivet in it I believe from the factory for shipping to keep metal insert from moving. I don’t think it was actually bolted up to the hood hinges prior to drilling. If I lay the hood onto the car with no hinges it looks like it’s in a very bad area to drill through. Can somebody send me some pictures of where the pins are mounted under the hood so I can figure this out.
