What is the correct master cylinder to use on a 1968 Dodge Dart GTS 340 that came with Kelsey Hayes MANUAL front disc brakes /rear drums? Year One, Classic Industries and Inline Tube don't really specify. (Does have 1" bore.)
As far as front brake rubber hoses I'm kind of running into the same thing. Did they use the same rubber hose on front manual Kelsey Hayes discs as front drum brakes?
Thank you
Mike
Thank you
Mike
