68 dart manual to pwr brakes
Dakota_Don
Hello i want to swap my manual to pwr brakes on my 68 dart,
I have a booster and brackets, the only thing i do not have is the MC and the brake pedal rod..
is the rod the same on the man and disc?
if not where can i get one new or used..
should i use a 68 disc MC or a later model?
thanks
Don
thanks
Don
Why are you moving to power brakes on an A body? Really not needed in an A body.
Sometimes the pedal firmness / travel or lack thereof, is a function of the piston bore size in the master cylinder. Matching the proper master cylinder bore size to the brakes takes care of this issue.
Mancini has the brake pedal / master cylinder push rod.
Be certain to let them know what your setup will be, because there is a grommet that attaches to, and locates the pushrod.
well I do have a ecent peadal, but seems like i need more psi to the brakes..
the dart has the OEM mc, which i beleive is a 15/16 bore (may be wrong)
so how do i determine what size bore? do i need to know my whl cly bore size and my caliper bore size? The bakes work good but it takes a lot of leg work to get this done.
