moparmat2000
I just wired in a light package w keyhole light in my 67 barracuda dash during rewiring of the dash. These werent available this way but i modified the car to have it in there. Anyways,
i used a 68 schematic for the map light part, and when bench testing all this i found that the map light will turn on automatically when its switch is in the on position as a floor courtesy lamp when the doors are opened, and with doors closed it will only light when you turn the headlight switch all the way up to light the dome lamp.
Can anybody here who has this option on a 68 dart verify if this is the correct operation of this? I noticed in the 69 wiring there is no maplight switch as it must be wired directly into the domelight circuit. I was assuming this was wired independently so when the doors are closed , you could turn on just the map light, and not night blind the driver.
This could be as easy as adding a 3rd lead into the switch itself, it seems to pick up its power off the door pin switch wiring, on one end, and uses accessory hot on the other end,
However if the way i wired it is normal operation for this, i will leave it be, as the dash is all boxed up and back in storage.
Thanks in advance
Matt
Thanks in advance
Matt
