MoparDemon
Just picked up this 68 Sedan on the weekend that is going to be used as my new daily driver, Has the 225 /6 with 70,000km on it! was owned by and elderly couple and taken care of...it has all of its original parts as far as i can see and everything works!...time capsule...even found the build sheet under the back seat too..take a look at the seat frame and foam it looks new.
As far as rust is concerned the quarter are the only area that look crispy but the trunk drops look mint and the inside of the trunk seems to be all surface rust..after i took the pics i took all the seam sealer off and banged all the areas of worry with a screw driver and it all seems solid so i will clean it up and treat it now before it gets worse, updates to come...
