68 Dart Wiper Switch ?????????
Theo
Member
Albuquerque, NM
I've searched the older posts, but no luck.
My Dart wasn't orig equipped with the electric washer. The Wiper Switch is p/n 2864415 and does not have the "W" terminal used to power a washer spray pump. Somebody added the washer spray bottle, pump, hoses, but never finished the job.
I have added the correct brown wire thru bulkhead conn pin M as per the schematic - but now I need the correct switch.
Pictures are of
1) my existing switch - which interestingly enough has a making for terminal "W" but has no terminal, and
2) the harnessing - which does have an empty contact cavity for the "W" terminal.
Can someone give me the correct p/n for the switch so I can "try" and locate one.
