[SOLD] 68 gts 383
gts330hp
Active Member
viroqua Wi
Rating - 0%
0   0   0
68 gts 383 dart vin ls23h8b------ in may of2008 galen govier look an decode the car. Vehicles currently registered in galen's registry as of it is one of #22 of 79 in vin sequence of all 1968 383-4 dodge dart 2 door hardtops accounted for the hamtramck, mi plant and buil to spec's for the u.s.a. Mileage on the car is 67,641 number matching engine and transmisson . Reading galen paper work quarter panels replaced, trunk in excellent condtion, floor is good condition, wheels, wheel are 70s rallys , 22 inch radiator #2898o33, drum brakes front an rear, manual steering. The car is apart for painting. Galen govier grade this car a 5. Lots of new parts door panels, carpet, weaterst stripping send a email for more. Will add more photo $18,000. looking to add photo no luck. for photo send a p.m.
Do you have pics of exterior,you mention disassembled at what stage?drivetrain in or out,body panels removed?
its all apart??
needs paint??
you want $18k
you post one close up of the motor??
