George R
Mopar Nutcase
Hi fella's. Moving along on my 69 Dart resto, I need to paint the engine. I'm doing a factory resto on this heap so I want to paint it the way the factory did.
Was the oil and temp sending units installed at time of paint?
Harmonic balancer?
Automatic kickdown linkage?
Distributor and hold down clamp?
Oil pan drain plug?
Power steering pump brackets?
Plug wire seperators on the valve covers?
How about the 3 bolts that hold the triangle alternator bracket to the H2O pump?
There are 2 areas on the block that have number stamps. Were these painted THEN stamped, left unpainted, stamped then painted over?
Any other advice you can offer? Things to paint, not paint, paint black, leave natural?
Thanks in advance for all the help so far with this car. I would never have gotten as far as I have without all the help from FABO members. Thanks guys.
George
69 Dart 340 Swinger
727 auto, P/S, PB
Harmonic balancer?
Oil pan drain plug?
George
69 Dart 340 Swinger
727 auto, P/S, PB
