[SOLD] 69 440 and 727 trans
swing69
I’m just an old guy……
Central NJ
1969 Steel crank 440 cu. in. Mopar (Dodge, Chrysler, Plymouth) big block engine. Full valve job, +.030w forged pistons, 6 qt. B/E body oil pan, new Eddy performer intake, fully balanced. Professionally built. $3000 in machine shop work alone! Engine is a non-HP market. Has an upgrade Crower Cam. Est. 400HP/400FT.Lb torque. On the engine stand, never installled or run.
1969 A727 big block automatic transmission. Professionally rebuilt too. TCI valve body, standard pattern (not reverse). Never installed, never run.
$3500 for the engine, $750 for the trasmission. $4000 for both. I will not sell the transmission unless the engine sells first. My luck, I'll sell the trans, wind up using the motor and have to go shopping for a trans! Thats NOT want to do!
Pick up in Hamilton, NJ - Near Trenton of I-195
still available, both engine and trans, ready to install, never installed or run...ready to go!
machine shop detail:
full valve job, guide liners, resurface heads, V1386/V1900 valves, S2970 seals, manley retainers, ARP rod bolts, pioneer locks, bore/hone with plates, check align bore and deck, recondition rods, clean/cut/chamfer crank, balance Assy, MK632D w/cam (upgraded to Crower 32918 (288H grind),
L2266F Forged Pistons.: $2966.96 (Automotive Machining Services, Schwenksville PA)
PLUS: Eddy 440 performer intake, 6 qt Mancini B/E oil pan, waterpump, chrome bolt kit.
Trans is also fully rebuilt with TCI 122400 Valve body, 128500 filter/gasket.
Available at extra cost: New mopar performance electronic ignition kit for 440s
No foolin; heres the BOTTOM LINE: $2900 for the engine; $3500 with the trans.....
PU only in central NJ. the sooner the better!
Now here this: $3K for the engine AND transmission. I want them gone. PU only.
Will hold in storage if given a deposit. PM if interested.
Hey, can you tell me what info is on this block (ie VIN, build date, etc.) I'm on the look out for the block of my '69 Charger. Is the transmission the same #s as the block? Thanks.
On the pad: E 440 with a 5 -14 under it. (corrected the typo.....I had E400 earlier, duh)
On the block: 2536430-8, Night shift, 2-24-69
Both were out of the same donor car, a 69 Imperial. I haven't looked, but I'd bet they are the same numbers.
On the pad: E 400 with a 5 -14 under it.
Thanks for the reply. Well if it was out of an Imperial, it definately was never in my Charger.
I don't mean to hijack but...
If you run by another 440 let me know the numbers. I know it ain't an A-Body, it's just where I started out, with B-Bodies. So if anyone can help me out that would be great.
Good luck on the hunt. You never know...you might get lucky and find them.
