moparmat2000
69-76 automatic console complete as shown in pix. This is everything you need to convert your 69-76 column shift to floor shift minus steering column. Door is correct with pushbutton for 71-76. 69-70 do not have this button. Will fit 66-68 with different shifter that has a neutral safety. All brackets, linkages etc included. Ashtray is included. Console light wire assembly is not oem but a part i manufactured to correct length with oem style ends. Correct for 69-76. New Year One shifter knob black pushbutton. Only Item missing is the transmissions shifter arm which is the same part as your column shift one. So you reuse your original one. Everythings in decent shape, needs to be restored a bit. Door hinge requires it to be bent into shape to fit the door closed better. Some parts have been cleaned, sandblasted, primered etc to get you started. This is pretty heavy and will ship UPS. Asking $550 plus shipping. Located in west Texas. I accept paypal.
