69 barracuda electric fan selection
Rulito
Active Member
Hello folks
Excuseme my bad english, i need your advice
Recently we repair my 318 engine.
I put 265 dual energy comp cam, flat top pistons, stock magnum heads with hughes springs, msd 6T, edelbrock 600 cfm carb and hooker headers.
I remove the stock 69 radiator and replaced with a 3 row 26" core radiator. Its wider than the stock one, but also its thinnest, so the distance between fan and this new radiator core its bigger (no shroud)..
At stop lights, the car is getting hot quickly, i am thinking on use a dual electric fans with a shroud to avoid that heating (this car is for weekend driven only)
What electrics fan would you recommend me? how many cfm?
I saw on ebay a shroud with two electrics fans (1400 cfm each) for about 169 dollars. this is the link
http://www.ebay.com/itm/271441757868
thanks in advance
You need to measure the distance between your water pump pulley and the core of your radiator. Then you will need to find an electric fan w/shroud that will fit in that space.
Use the search function and you will find lots of good information.
That car shouldnt get hot even without a schroud, Ide look for other options.
I am thinking use a bigger fan spacer. At least a bigger one enough to restore the original (that i had with the previous radiator) distance between the pulley and the radiator
