69 barracuda info request.
3404spdfish
montana
looking for pictures of a 69 barracuda with factory disc brakes up front also must have sway bar bracket on LCA. i do have a few question.... are the spindles from the B,E body the same as A body are the rotors bigger in diameter for B, E body
ok i was just looking for rotor clearance for the bolts that hold on the lower ball joint to the spindle
