ConfusedMuchOfTheTime
Active Member
Good {}.localdaypart(). Mine is morning so good morning. I need to source all the gearshift unit parts from the gearshift knob/reverse button through to the swivel assembly inclusive for my '69 Dart. I have the transmission control lever. I've researched this a bit and given I have the NSS on the 904 trans I do NOT require a gearshift unit with the NSS bolted to the gearshift unit housing as per earlier years (pre-'69). This being the case, can I select say a '67 or '68 gearshift unit with the NSS bolted to the side with the violet and white wires (one of each) and simply remove the switch/discard and bolt the gearshift unit to the trans tunnel bracket and job done ?
Is communication between the transmission control lever and the NSS inside the 904 via the switch operating cam ?
Thank you in advance everyone.
